if i want to target the existing surface beyond the edges of my road/sidewalk, should i use the link slope to surface subassembly at both ends? i want the model to test if in a cut or fill situation, and then target.
Are you wanting just a simple daylight slope?
In that case, in the stock subassemblies, I would use the Daylight General. You can place it at the appropriate spot in your assembly, and set the Cut/Fill options in the properties window.
There are more complex ones available, too.
