when i select an object with the quick properties on my cursor turns into the standard windows pointer like as though i have another window active and i need to pick in the drawing area before i can select anymore objects. this doesn't happen in plain autocad. my pickadd is set to 1.
has anyone else noticed this. its kind of a time waster...
This is known issue. See this link: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/2013-Quick-Properties-and-extra-clicks/td-p/3...
neilyj (No connection with Autodesk other than using the products in the real world)
It looks like it's fixed in 2014. The very first time I tried it. I behaved as it use to. Got a windows cursor. But every try after that and it worked as it should. I've only tried 2 drawings so far. But it seems to have been fixed.
Allen
Allen Jessup
CAD Manager - Designer
