I am working on a proposed grading surface that contains feature lines in Site 1. I created a three additional feature lines in a site called Work Site. Now Quick Elevation Edit will not recognize the feature lines in Site 1. The only way I found to get it to recognize the FL's in Site 1 is to delete Work Site.
After some testing this appears to happen as soon as you create an additional site even before you add feature lines to it.
Is there a way to set the "current" site? How do I get Quick Elevation Edit to recognize FL's in other sites?
Jeff Paulsen
C3D 2009 v3.1
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
