Valued Mentor
Hidden_Brain
Message 1 of 4 (227 Views)
question about structure insertion point and pipe connection point
227 Views, 3 Replies
01-23-2014 04:01 PM
please see attached image, i have a big structure 96"x102" to inner walls with 6" wall thickness. i have two 48"x76" pipes connecting to it, which have 6.5" wall thickness. the problem is that the pipes seem to "connect" to the insertion point of the structure, which is the grip highlighted in the attached image. i am using a rectangular juction structure NF, with a custom block that shows the grate, the curb piece and how the curb piece lines up with the curb line. the pipe coming into the structure from the north is ok, but the pipe leaving the structure to the right shows up partially outside the structure limits (see attached image). is there a way to fix this, so that the pipes to not "connect" at the structure insertion points?
Avishek Chhibber, P.E., CFM
Civil 3D 2013 SP2, Win 7-64 bit
8GB RAM
mathewk
Message 2 of 4 (213 Views)
Re: question about structure insertion point and pipe connection point
01-23-2014 04:39 PM in reply to: Hidden_Brain
You can select the pips grip and move it so that it's where you want it. Don't move it too much or it will become detached.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Jay_B
Message 3 of 4 (201 Views)
01-23-2014 05:22 PM in reply to: Hidden_Brain
Some of the suggestions in this thread might also help.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Pipe-Networks-Connect-to-Part-issue/m-p/39473...
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Valued Mentor
Hidden_Brain
Message 4 of 4 (187 Views)
01-23-2014 06:49 PM in reply to: Jay_B
thank you guys, looks like there is hope! you guys are geniuses! I will try the pipe grip edit tomorrow and post back. thank you again!
8GB RAM
