Civil 3D Forum
question about structure insertion point and pipe connection point
3 REPLIES 3
Hidden_Brain
770 Views, 3 Replies
please see attached image, i have a big structure 96"x102" to inner walls with 6" wall thickness. i have two 48"x76" pipes connecting to it, which have 6.5" wall thickness. the problem is that the pipes seem to "connect" to the insertion point of the structure, which is the grip highlighted in the attached image. i am using a rectangular juction structure NF, with a custom block that shows the grate, the curb piece and how the curb piece lines up with the curb line. the pipe coming into the structure from the north is ok, but the pipe leaving the structure to the right shows up partially outside the structure limits (see attached image). is there a way to fix this, so that the pipes to not "connect" at the structure insertion points?
3 REPLIES 3
mathewkol
in reply to: Hidden_Brain
You can select the pips grip and move it so that it's where you want it. Don't move it too much or it will become detached.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Jay_B
Some of the suggestions in this thread might also help.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Pipe-Networks-Connect-to-Part-issue/m-p/39473...
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Hidden_Brain
in reply to: Jay_B
thank you guys, looks like there is hope! you guys are geniuses! I will try the pipe grip edit tomorrow and post back. thank you again!
Rail Community
