Civil 3D Forum
Question about Design Checks Items into Civil 3D 2012
2 REPLIES 2
192 Views, 2 Replies
anybody can help me with the following question:
I need to create the Curve Design Check for alignment, with following items:
If Design Speed = 100, Delta Angle <=2grad, Length = 275
If Design Speed = 100, Delta Angle <=3grad >2.01grad, Length = 250
If Design Speed = 100, Delta Angle <=4grad >3.01grad, Length = 225
If Design Speed = 100, Delta Angle <=5grad >4.01grad, Length = 200
If Design Speed = 100, Delta Angle <=6grad >5.01grad, Length = 175
Thanks in advanced.
Best regards, Daniel.
AutoCAD Civil 3D 2012 with SP1
2 REPLIES 2
plase, help me with this topic.
thanks in advanced
regards, daniel
Cadguru42
Have you looked into the design criteria XML files?  They are located in C:\ProgramData\Autodesk\C3D 2012\enu\Data\Corridor Design Standards\Imperial.  You can copy one of the existing ones and then change the numbers in the XML file yourself.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Rail Community
