Hello!
I have a question.
I am civil engineer. I work with road projects. I am in the first steps of using the cad civil 3D, and normally I have some difficulties.
My question is:
When I begin to work, the first phase is to get the topographic plan. The problem is that when I open this plan in Cad civil 3D this is as 2D drawing and I can't use the command of civil 3D. I know to import the the point data from file csv, but the topographic engineer always gives the topographic plan in cad format 2D.
Someone told me that there is a way to convert the drawing 2D to file csv, ( I don't know this action), and I need a solution for this.
thanks in advance
Edited by
Discussion_Admin
Now I'm confused. You have received a different drawing than the one you posted earlier? Can you post this new drawing?
Hi Steve,
I think something is wrong with the dates in this thread. I see 3 post from the OP that have have yesterday's date but I know were earlier posts. This includes the one about the drawing you responded to. I also got email updates about those posts. I don't know how just the dates for those posts changed. Strange!
Allen Jessup
Engineering Specialist / CAD Manager
Hi Allen!
Based on your suggestions I could create the surface. I discussed all the problems found by you in the first drawing and the topographer send me another file in the format csv. It seems ok now.
But I have another question, that I would like to have an answer, even It doesn't affect to continue me design.
When I go to drawing setting to change the units and select the units from feet to metric the elevation change.
If the units are in feet, the elevation are the same with the elevation that are in the file format csv, if I change the units in the drawing from feet to metric the elevation are not the same with the ones in the format csv.
I don't know why It happens!? It depends from the way the topographer have worked?
In attach you will found the file
I'll take a look at it when I have the opportunity.
Can you say which elevations are changing? Points? Drawing? Surface? Also. Would you please post the CSV file.
Allen Jessup
Also could you please specify where you are changing the Units.
Allen Jessup
