Civil 3D Forum
Query Alter Properties
5 REPLIES 5
teflon
361 Views, 5 Replies
I have lots of text objects, value of which should increase by let say "100" units. These texts are part of a chainage.
The only solution I come up with is by making a query and altering contents with an offset. So far so good!
But I can not get the expression right.
What is the syntax for adding 100 to ^AcDbText.Text.Contents ?
The other problem is to know if ^AcDbText.Text.Contents is a number or text ?
5 REPLIES 5
Neilw_05
in reply to: teflon
I think you are querying a custom object such as a C3D label. Try it on genric text objects and see if it works. Map doesn't support C3D objects.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
teflon
in reply to: teflon
It is a text object, that´s I am sure of!
But what is the syntax for expression "actual value + something i want to add"  as the pic shows?
Neilw_05
in reply to: teflon
Rather than use a map query, why not use the express tool for renumbering text?
WIN 10 64 PRO
teflon
in reply to: Neilw_05
Thanks! It would work!
But I still would like to know the correct syntax for writing an expression!
Let say I got a chainage like this:
10
20
30
40
And I want to change to:
0+010
0+020
0+030
1+000
neilyj666
in reply to: teflon
Think I'd just create new alignments set to a suitable style and then label them as required?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
