I have lots of text objects, value of which should increase by let say "100" units. These texts are part of a chainage.
The only solution I come up with is by making a query and altering contents with an offset. So far so good!
But I can not get the expression right.
What is the syntax for adding 100 to ^AcDbText.Text.Contents ?
The other problem is to know if ^AcDbText.Text.Contents is a number or text ?
I think you are querying a custom object such as a C3D label. Try it on genric text objects and see if it works. Map doesn't support C3D objects.
It is a text object, that´s I am sure of!
But what is the syntax for expression "actual value + something i want to add" as the pic shows?
Thanks! It would work!
But I still would like to know the correct syntax for writing an expression!
Let say I got a chainage like this:
10
20
30
40
And I want to change to:
0+010
0+020
0+030
1+000
Think I'd just create new alignments set to a suitable style and then label them as required?
neilyj (No connection with Autodesk other than using the products in the real world)
