Civil 3D Forum
QTO Units in 3d not 2d
5 REPLIES 5
Jon0001
380 Views, 5 Replies
Hey
SO i have a problem i have my csv built and it works except it is giving me my pipe lengths in 3d not 2d i have used LNFT no spaces after or before  and all i get is 3d length.
Any help would be great.
5 REPLIES 5
Pollmuller
in reply to: Jon0001
Try connecting your CSV points with Line instead of polyline or 3dpoly. That will give you a true 2D length.
Erika
AUTOCAD Civil 3D 2013
Windows 7
Processor: Intel (R) Xeon (R) CPU W3565 @ 3.20GHz
Installed Memory (RAM): 12.0GB
System Type: 64-bit
Erika
klugb
Jon,
What version are you using? I have our 2013 version setup to use the CSV file with our pipe network and it reports the 2D length of pipe. I'm not sure how I could make it even give the 3D length?
Are you assigning the pay item in the parts list or manually assigning them to the pipe?
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
BrianHailey
in reply to: klugb
I'm seeing the same thing as Jon (I'm assuming that is the original posters name, if it's not I apologize). I have a pipe that is 500' long (in plan view) with a change in elevation of 50' (just for testing purposes). When I run the QTO tools, it gives me a length of 502.49' (which is the 3D length).
Bruce, are you adding the pay item through the parts list or adding it to the pipe through the QTO tools?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Jon0001
in reply to: BrianHailey
I have tried to mannualy add and through the part list i still get 3d lengths.
klugb
I must have changed my default when setting up the template.
See image.
Bruce Klug, P.E.
Civil 3D 2023.2.1
Rail Community
