Civil 3D Forum
QTO Manager - Takoff
15 REPLIES 15
Message 1 of 16
ccookusi
1694 Views, 15 Replies
What is the correct format for the .csv file to be imported into QTO manager?
The attached file loads into the QTO manager, but I cannot get the "units" to behave.
Every item I assign to an line or pline gives me a count instead of a length.
Also, how do you change the precision (decimal places) of the report.
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
NVMe Samsung SSD 960 Boot
16 GB Ram
15 REPLIES 15
Message 2 of 16
in reply to: ccookusi
Your CSV file looks fine.  When assigning a
pay item to a polyline, you need to assign a pay item that has units associated
with length.  There are several in that CSV file towards the bottom (i.e.,
those with units of 'LNFT' (linear feet)).
The 'EACH' and 'LPSM' pay items will just count
the number of entities with those pay items (not the area nor
length.)
For a list of acceptable units, you can look in
the file
    C:\Documents and Settings\All
Users\Application Data\Autodesk\C3D 2010\enu\Pay Item
Data\Units\QTOUnits.xml
Tom
Autodesk Civil 3D Team
What
is the correct format for the .csv file to be imported into QTO manager? The
behave. Every item I assign to an line or pline gives me a count instead of a
length. Also, how do you change the precision (decimal places) of the report.
Message 3 of 16
ccookusi
Tom,
Did you try the CSV file that was attached?
It is formatted properly and does not work.
Also, what about the precision?
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
16 GB Ram
Message 4 of 16
klugb
I have not used the QTO stuff yet, but if it's a "CSV" file format then how can you have commas in the description column?
Wouldn't that put the second part of your description into the unit field?
Bruce
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 5 of 16
We took another look at this file and discovered
that it has some extra white space that is causing the issue - probably an
inadvertent space when inputting the units. That is causing the LNFT units to
perfectly match the units found in the QTOUnits.xml file and defaulting back to
a count. Try removing the spaces, and your file works correctly.
You can change the precision by editing the
precisions in the TakeOff command settings.
Hope this helps,
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
What
Message 6 of 16
fcernst
'Your CSV file looks fine.  When assigning a
those with units of 'LNFT' (linear feet))."
Tom,
You are the original architect and developer of QTO. Please give us a status on the ongoing repairs.
We have a current roadway project that we need QTO operational for immediately...
The documented software defects are:
1) We need to report and calculate formulas with Areas that are not projected to the XY plane.
2) Formula math errors
3) Duplication of areas in subassemblies due to duplicate coding of inks.
4) The 3D length computations do not work even though we have 3D length selected in the settings (see below).
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 7 of 16
Discussion_Admin
in reply to: fcernst
Please note any account with an asterisk beside it is a old nntp account and no longer receives forum postings as nntp is no longer supported protocol here in the forums.
Discussion_Admin
Message 8 of 16
fcernst
Ok thanks.
Please update this to Tom's current account so we can get some feedback here on this important issue.
Fred
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 9 of 16
Discussion_Admin
Sorry but it just doesn't work that way this post was made with an older account. There is no may to make it state that it was some one else.
After a quick search there is no similar active employee account that I see. But you are welcome to search for his name in the user accounts all employees will  have a Icon like the one on this account.
Discussion_Admin
Message 10 of 16
fcernst
in reply to: Discussion_Admin
Here he is:
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 11 of 16
Discussion_Admin
@fcernst wrote:
Here he is:
Note the asterisk? Verified employee accounts looks like this Moderator @Discussion_Admin
But with a full name I did check the directory for you and there is no Inzinga at all listed.
I have read your posts in several threads on this issue in the forums. You do know that this is primarily a peer to peer discussion board and almost none of the team members hang out in here with regularity.
Even if you ran one down they could not tell you about any upcoming patches or fixes corrections etc. Autodesk being a publicly traded company and all.
Just trying to say there are better venues if you are trying to make sure the team knows about it.
Discussion_Admin
Message 12 of 16
fcernst
As an Administrator, you are not consistent though, that's why I pulled it.
For example, here's a post just yesterday from an employee with no logo:
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 13 of 16
Discussion_Admin
Thanks for the info.
We update them as soon as possible that one has been updated.
If you run across any more active employees with out the proper role you can use the
Report Inappropriate Content Button to notify us.
Discussion_Admin
Message 14 of 16
fcernst
"....any more active employees with out the proper role you can use the
Report Inappropriate Content Button to notify us."
Oh, are you talking about the substance of what Team Members, who never visit here,  are saying these days,  or are you talking about the Logos again?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 15 of 16
Discussion_Admin
No control over who,what and when employees post ( primarily peer to peer discussion) but if an employee does and has not had their account set to an Autodesk employee role as your example above then let us know with the button and we'll get it corrected.
Discussion_Admin
Message 16 of 16
fcernst
Oh ..Ok..gotch ya!
Can I still use that Button though if I don't like what they're saying?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Rail Community
