Civil 3D Forum
PVI remains after creating vertical curve
5 REPLIES 5
Steenix
805 Views, 5 Replies
I have a profile view of a street surface which transitions from a 2.75% grade to -0.52%. I would like to add a vertical curve so I can add a label at the high point of the street. However when I create my vertical curve, the original PVI is still there and the surface uses the PVI's elevation rather than the vertical curve's.
How can I get the PVI to either go away or have the surface read the vertical curve below the PVI?
Thanks in advance,
Austin
5 REPLIES 5
Jay_B
in reply to: Steenix
Are you sure those lines to the PVI from PVC & PVE aren't just "Line Extensions" in the Profile Style that can be turned off?
Settings Tab Toolspace>Profile>Profile Styles>Style name>Display Tab>Line Extensions - visible
As far as the surface not honoring VC elevations, if this is a corridor surface, has it been rebuilt since adding the VC?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Steenix
in reply to: Jay_B
Jay,
Thank you so much! You hit the nail on the head with both of those suggestions. I rebuilt the corridor which fixed my elevation issue, and turned off line extensions which fixed my profile view. You just saved me from hours of frustration, thanks again!
Austin
Jay_B
No problem, glad to help.
C3D 2018.1
C3D 2016 SP4
wfberry
Quite frankly, I am not sure why you would not want to show the PVI.
troma
in reply to: wfberry
It would probably depend on the drafting standards mandated by the authority to whom the drawings will be submitted.
Mark Green
Working on Civil 3D in Canada
Rail Community
