troymoore7595
Message 1 of 2 (195 Views)
Publishing Issues
195 Views, 1 Replies
08-11-2011 10:10 AM
Has anyone had this problem ?
I am going to print a very large document (47 pages). I have the page setups set to print to a pdf writer. We use the cute pdf writer program. Never had any probelms with it before. If I print to the pdf writer one sheet at a time. Works great. If I publish, all of the layers turn on in each sheet in the pdf.
Troy Moore, PE
Windows Vista
Civil 2012
Troy Moore
Civil3D 2014
Windows 7 Pro, 64 bit
Intel Xeon E31225 @ 3.40Ghz
16 GB RAM
Product Support
AlmasSuljevic
Message 2 of 2 (171 Views)
Re: Publishing Issues
08-12-2011 09:08 AM in reply to: troymoore7595
Hi Troy,
Not sure about cure PDF, but I find that DWG to PDF.pc3 (installed by default) works OK for me. Few things I do remember, thought, is that PUBLISHCOLLATE system variable controls the plottings of individual sheets or multiple sheets. But most likely, the issue you have is taht your memeory cannot handle all sheets. I would suggest trying to plot in smaller groups.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
