Himanshu,
I'll try to answer your questions.
Could you post some more details on this? You're saying that the pipe
network is data-referenced into the drawing that has your view
frames/sheets, and then you create sheets in that same drawing, correct? Correct, for example I have a Design.dwg where I built the pipe network, and I make a datashortcut and reference the network into a Sections.dwg where I then make section view, and set up the paperspace with the plan sheets.
So the pipe network shows in the drawing in model and in the sheet
layout view, but not when you plot it? If I plot from that Sections.dwg by plot/publish of the sheets/layouts, it will show up. But, it doesn't plot when the drawing was closed, and I publish those sheets/layouts from Sheet Set Manager. As the Publish is going on, I can see the drawing open up momentarily and it doesnt appear to be syncronizing the data ref of the pipe network. When I look at the finished product (paper, pdf, dwf) the pipe does not show up in the section views. I can then go into the Sections.dwg, where I have referenced the network into, and I will have to manually syncronize the pipe network to make it appear in the sections.
Are you not seeing the pipe network in a plan view, or are talking about
the pipe network parts in a profile view? Uhmm, just the Section View. I haven't tried to print a plan and profile sheet with the network data referenced.
Does publishing fail only when you try it from SSM, or does it fail even
when you plot/publish from Civil 3D? Publish fail..?? I wouldn't say fail, I would say the datareference isn't sync'd, and it has been just from the SSM Publish from my experience.
Thanks.
