Hi Everyone,
I have installed Infrastructure Design Suite 2014 on one of my users' workstation and one of the several problems she is having I can't find info on anywhere: When she uses the DWG to PDF driver she is getting strange artifacts that, at first glance, look like little blocks randomly placed around her drawings. These are always over/ in viewports. They do NOT show up in plot preview. I tried plot and publish. Both give same results. When zoomed in you can see they are tiny little viewport control dialog boxes that seem to have been placed on the plot at random. See screenshots attached. If anyone has the same problem I would love to hear it (and see an example!! I don't expect much of a solution here considering what else I've seen in response to 2014 problems but any help would be appreciated. Thansk!
Try downloading a free pdf driver such as bullzip or similar and use the driver from that to print rather than the DWG to PDF
I can see that it is the navbar, but that is turned off before plotting aleady. If you look at the attached jpeg called zoomout you will see how tiny the little rectangles are. Only after zoomin in to a tiny area of the image can you tell it is the navbar and even then it's vague wihtout hilighting it and incresing the contrast.
Other PDF drivers are having the same issue. Tried PrimoPDF and PDFCreator. No luck. It's definitely in 2014.
Thanks though.
I've seen this in 2011, and hardcopy as well as PDF. Its an artifact of the printing process rather than any specific driver.
I am getting the same results since Installing IDSP 2014. Only I am using IDSP 2013 to print. Turning the NAVBAR worked. Thank You.
