Civil 3D Forum
Publish to PDF Sheetset Mgr - .DWG to .PDF Plots offset
2 REPLIES 2
972 Views, 2 Replies
When I try to plot a set of files to one PDF, all my plots offset to the right.  This never happens if I Publish to Plotter through Sheetset Mgr. or use the plot dialog in C3D.  Only Publish to PDF through Sheet Set Mgr.  Does anyone know of a setting I should check?
2 REPLIES 2
AlmasSuljevic
Did you try selecting new window in Plot dialog (what to plot) instead of extents? Then see if program gets better area. Try print preview to see. Also do you get the same bahavior if you use DWG to PDF.pc3?
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Joe-Bouza
Sheet set manager want you to use Layout, not extents or window. Also, does the review of you pagesetup show correct?
Joe Bouza
Rail Community
