I'm trying to publish a set of drawings into seperate PDFs. I've tried running the Multi-sheet and the Single-sheet options and they are both printing all sheets into one PDF. Is there a configuration variable or another setting somewhere that would be blocking me from printing to seperate PDFs?
PUBLISHCOLLATE
0 A published sheet set is processed one sheet at a time. Separate PLT files are created for each sheet. If the sheet set is published, the sheets might be interleaved with other plot jobs.
1 A published sheet set is processed as a single job. A multi-sheet PLT file is created. If the sheet set is published, it is never interleaved with other plot jobs.
