With Autocad 2013 we have found an unconsistant problem with overwriting PDF files with same name. This only happens with publish command (ie, can just plot 1 layout to pdf and overwrite no problem). The funny thing is, it doesn't happen all the time - just 50% of the files (and yes, the file is not in use when attempting to overwrite). Any thoughts?
Under Plotter configuration for PDF plotters there is a prompt when overwriting existing files checkbox.
We have multiple Adobe pdf plotters / Setups
This setting is not the same in all of them but they probably should be.
Is it always the same PDF plotter causing the varied results?
Is it always the same user overwriting the files?
Is it always the same file(s) that overwrite?
And lastly,
is it always the same computer that is the culprit? Always prompting or always overwriting or just doing whatever it feels like doing.
Actually,
Even thought it appears to be doing whatever it feels like doing, It doesnt feel and actually follows logic, belive it or not. LOL
Where are u looking on plotter configurations settings? This is using the autocad DWG to PDF. As said, sometimes works, sometimes doesn't (error is 'open in another program') - its all computers, all random, and as mentioned, if I just use the plot command for 1 sheet, it overwrites fine.
Under options there is a plot and publish tab.
There is a default plotter.
DWG to PDF does not seem to have a setting for asking before overwriting file.
ADOBE PDF does have a check box for asking about file overwrite.
that was why I asked who what when and where.
yeah, PDF exchange is the only other option we have. Our company is very specific about which add-on software it allows.
Check page setup manager (on layout tab in dwg) for the ones that overwrite automatically. See what the plotter is.
Check again for the ones that prompt for a filename before overwrite.
I bet they are not all using DWGtoPDF.pc3
If you are publishing from a list that you have picked of dwgs, then the page setrup is controlling the game for each plot.
nope, all the same dwg to pdf, same settings every page (which makes sense as I started with one layout and just copied). Definitely some quirk related directly to publish command. Will try to pay attention for next one I plot with no problem and then compare to that.
WOW,
maybe all this time my computer has been doing EXCATLY what it feels like doing, all the time letting me FEEL like I am in control.
I have a few minutes, I will scratch my head some more on this one.
