we have a new installed version of civil 3d 2010. i am having a issue printing from a sheet set or publish to ,pdf
the error says no device found. there are pdf writers there. adobe 10, cute and nitro. i can go out and write each sheet
individually to pdf but i don't want to do that when i can send a 23 page set from sheet set and let it do it for me. and no stinking help for IT. any ideas out there
thanks
Do you have the DWG to PDF driver listed that is supplied by autodesk? My recollection is you need to have the DWG to PDF.pc3 in order to use the direct to pdf option in the publish command. o you would need to be sure that pc3 was there or it will give you the plotter not found message
