Civil 3D Forum
Protoype set up
9 REPLIES 9
Message 1 of 10
Joe-Bouza
901 Views, 9 Replies
Protoype set up
My standards set up has been nebulous at best and I am finaly taking the steps to memorialize and document them.
Here is my question: our work flow uses xrefs for layout, grading, utilities, traffic and landscaping. I am contemplating putting all the layers in the civil3d prototype and creating filters for the various diciplines. My though was that this would be easier to maintain but I am worried that the filters may impead performance; I have read conflicting post regarding filters. Some say they help perfomance other say performance issues are related to them? I could see if I had a bazzilion filters I'm thinking in the order of a dozen or 2.
Or would I be better off draging only the needed styles into the xref prototypes? (that one stinks of drudgery). And then I have the sheet files - I'd like to have as few layers as possible in them? what are your thoughts?
Your Name
Your Name
9 REPLIES 9
Message 2 of 10
Jay_B
in reply to: Joe-Bouza
Hi Joe,
Sounds like we have a workflow and dwt setup similar to yours.
We have 3 main source c3d base file dwt's. One for most everything and one set up for cross sections with different vp scale and proper section view graph scales. Other than the scales they are the same dwt's.
For Surveys we have a Survey.dwt for parcel sketches boundary surveys etc.
Our base dwt's have 400 layers in them so we decided to go with the filters and initially only had them in the base dwt's. Then users liked them and requested they be added to the Plan Prod. dwt's and now all of our templates have the filters.
I've also read various things re: layer filters affecting drawing performance but I've not yet seen an issue related to having the Filters (we have around 3 dozen) in ours. I've attached our list which is also split into categories.
We are beginning a large implementation of 2014 this week and we've had to add all styles to our Plan Prod.  Templates due to the current behavior of 2014 C3d 2014 SP1 create sheets routine having changed.
In 2012 we had very simple Plan Production dwt's with very few (10 or so) layers *G-ANNO* was about it.
As I mention in the other post now with 2014 unless something gets fixed it's necessary to have all needed styles reside in the Plan Prod. dwt (which obviously means the layers as well.
With Import Styles there are many Command & Feature Settings that don't go along for the ride but with the old sheet creation behavior those all magically used to happen magically behind the scenes in sheet creation routine.
If you do choose to implement the Layer Filters in case you're not aware, Layer Filter Import / Export functionality exists in Map & C3d using LAYERSAVEFILTERTREE and LAYERLOADFILTERTREE commands. These were a life saver.
Good Luck.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 10
mathewkol
in reply to: Jay_B
Nothing to add here guys, but Jay, that was one of the most useful and well thought out posts I have seen in a while.  Kudos!
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 4 of 10
Joe-Bouza
in reply to: Jay_B
Thanks Jay.
Yes it does look like similar WF. thanks for the response. I will be going with the filters. thanks for the commands; I could not find them on my own even via goole so I got a free one from DS. I'd rather use the OOTB
Your Name
Your Name
Message 5 of 10
jmayo-EE
I agree Matt. Well done Jay.
Joe if you have hundreds of layers in the template w/o filters I would think the layer manager and layer dropdowns will pour like molasis...Your users may find drudgery with these commonly used tools.
John Mayo
Message 6 of 10
Joe-Bouza
in reply to: jmayo-EE
agreed. The filters are in. 🙂
Your Name
Your Name
Message 7 of 10
AllenJessup
You've already made the decision but I'll just add. I use a similar setup regarding filters and haven't noticed any large problems with a few dozen filters. I think they got a negative reputation when there were a lot of architectural drawing with hundreds or thousands of filters and no way to clean them.
Allen
Allen Jessup
CAD Manager - Designer
Message 8 of 10
Joe-Bouza
in reply to: AllenJessup
Ah yes I've seen those bugger inserting a building foot print
Your Name
Your Name
Message 9 of 10
Lisa_Pohlmeyer
I was hoping to deploy 2014 with SP1 fixing the section editor issue this week, but then they introduced this error, http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Civil-3D-2014-S-P-1-0-Bug-Material-calculatio...
Guess we'll wait longer.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 10 of 10
Joe-Bouza
in reply to: Lisa_Pohlmeyer
Thanks Lisa
Your Name
Your Name
Rail Community
