tbronson
Message 1 of 5 (560 Views)
Prospector Northing/Easting precision
560 Views, 4 Replies
08-30-2013 01:36 PM
C3D 2013.  When I look at _All Points in the prospector my coordinates (northing/easting) have a precision to four decimal places.  How do I change this to default to two??
Thanks in advance.
Todd
doni49
Message 2 of 5 (555 Views)
Re: Prospector Northing/Easting precision
08-30-2013 01:49 PM in reply to: tbronson
  1. Toolspace>Settings
  2. Right click on your drawing
  3. Then click on "Edit ng Settings".
  4.  "Ambient Settings" tab
EDIT:  When I tested this, the change didn't take effect until I saved, closed and reopened the file.  And I'm on C3D 2012
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Cusomization
tbronson
Message 3 of 5 (551 Views)
08-30-2013 01:53 PM in reply to: doni49
Awesome!!  That worked great.  Didn't realize there were ambient settings there also.
Thanks.
doni49
Message 4 of 5 (544 Views)
08-30-2013 01:57 PM in reply to: tbronson
Thanks.
Glad to help and I didn't know it either.  I just looked around for something that I thought might do it.
Don Ireland
Forum links:
Civil 3D General
New Member
JRumpel
Message 5 of 5 (351 Views)
03-21-2014 09:38 AM in reply to: tbronson
I had the same problem, but changing it in the drawing settings didn't work for me, so here is the solution a classmate found:
*Also, the ambient settings didn't show that an override was happening, which was a little frusterating
There were only three points to edit, so I first did this individually (opt b) but the pictures show how to change it for that entire label style(which would have been smarter to do in the first place)
For option B, it will bring you to the same style menu, but will only change the point selected.
While I was in this menu, I also changed the semi-colon to '='
I still don't know how to find where to change the point style for a specific label style, so I had to remove the point marker in Panorama.
If anyone else had this problem, I hope this helps :smileyhappy:
