Civil 3D Forum
Proposed surface not linking to the correct codes of the assembly in my corridor
1 REPLY 1
Hamassein
183 Views, 1 Reply
When I paste the proposed surface with the corriodor surface and I check the profile the proposed surface ties to the bottom of the kerb ignoring the footpath. I don't know if anyone has had this problem, if so how to fix it. Also in the same drawing file I can't seem to export it to ACAD.
1 REPLY 1
jporter
in reply to: Hamassein
You can't export to ACAD?!?! sounds like a corrupt drawing. Run a RECOVER (RECOVERALL if you have xrefs) or an AUDIT to see if that helps.
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
Rail Community
