Civil 3D Forum
Proposed profile and existing surface not showing in Profile
3 REPLIES 3
2777 Views, 3 Replies
I have a profile showing proposed storm sewer, existing sanitary, rock surface, existing surface, and proposed profile. Today for some reason the proposed profile and labels, and the existing surface are not showing on the profile and I'm not sure what has changed or how to get them back.
3 REPLIES 3
Jay_B
Is this a Profile in a plan and profile sheet and are data references being used?
If so see the solution to This post.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
in reply to: Jay_B
Yes Data sources are being used for the existing surface but the proposed
profile was drawn on the profile when I first created it. And the profile is
just in model space. The red line is the rock surface but there should be
the existing surface and the proposed profile above it.
IVS2112
Dont worry,  If you 've the bak. up file of the drawing, problem wil be solved.
waht's you version number??
any version.... you may goto the file option, select the DRAWING UTILITIES, then select the RECOVERY option.
then automaticallyy your old drawing file will be come back.
Rail Community
