AutoCAD Civil 3D General Discussion
Habib_Nespak
Message 1 of 3 (193 Views)
Accepted Solution
Proposed and Existing Elevation on a single Point
193 Views, 2 Replies
02-06-2014 02:24 AM
dears
i want to show a two elevation like ground level and proposed level at same point and want to find the difference of elevation.
please help me in this regards
Habib Ahmed
If all you are looking for is "want to find the difference of elevation", then all you need to do is create a "Tin Volume Surface".  A tin volume surface is the difference between two existing surfaces in Prospector. I.E., contour lines will represent the difference between surfaces at any given point.
Bill
*Expert Elite*
Joe-Bouza
Message 2 of 3 (172 Views)
Re: Proposed and Existing Elevation on a single Point
02-06-2014 04:31 AM in reply to: Habib_Nespak
Use a reference component in your label style to pick up the second surface
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
*Expert Elite*
wfberry
Message 3 of 3 (163 Views)
02-06-2014 05:10 AM in reply to: Habib_Nespak
Bill
Post to the Community
New Post
Need installation help?
