Hi there,
Can I create a point group that will pick up all evelvation that have "*PROPERTY NOT SET*"?
This would be handy.
Allan
Allan,
I don't think I've ever seen a "Property Not Set" Point Elevation. You can Exclude every point in a useful elevation range, and you should be left with everything else. You can also do quite a bit with the Query Builder Tab.
Dave
Dave Stoll
Las Vegas, Nevada
Thanks Dave,
we normally use a rule. e.g. important point for position, either a -999 or -899 at elevation.
But it wopuld be handy in to include "PROPERTY NOT SET" as a null point.
Cheers
Allan
The problem is that the elevation parameter only accepts a number, and PROPERTY NOT SET doesn't qualify. As a test I created a group which excludes all elevations >= -99999999999999999999999999999 That test excludes all possible elevations, so the only points which could be included in this group are the ones with no elevation at all.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Except I can't get it to work to exclude points with elevation <100. It still keeps the points with no elevation. I want them to go away as they clutter the screen.
2014 SP2
