Some changed.
When I pick a feature line, the property dialog would show Feature line, and list the information.
Now for some reason, I get aecc_feature_line and the property dialog shows a different list of information.
How do I get back to the Feature line list.
Until someone comes by with a solid "this is what it wrong, I guarantee it" type answer..... I would try running a repair to fix the registry entries associated with the Properties dialog.
Is 'feature lines' the only thing messed up?
Did you by chance load Map or Autocad rather than C3D? When you install the product you also get icons to run those products without loading C3D.
Good call. Just tested it and that is exactly what happens when you're in object enabled "cad", but not "C3D"
no
I have tried different profiles.
Not sure when or why, but what occur was the computer lockup, had to turn off the computer, didn't have a network connection, lost menus. I reloaded the menus. I also turn off some services to speed up the computer.
I went to change the feature line style, and I did not see it in the property menu, which I have done many times. I kept looking and saw stye was gray out, but swore the stye was at the top of the list. As I try to figure out why it was grayout, I then notice the different name. went to another computer and it work as before, so I wasn;t losing my mind.
I exported the working profile and then imported it, still not working.
I just open C3D 2014, and I have the same problem. So something is very screwup.
Have you tried resetting your C3D profile to the default?
This is sounding like the old Land Desktop problem where the profiles would get crossed up and nothing would work. I think what would happen is the ARX/DLL files needed to process the objects were not getting loaded.
Sounds similar here, I would try @Neilw_05's suggestion, hopefully that will restore it.
Mark Green
Working on Civil 3D in Canada
okay;
I don't know what when wrong, but it working now.
I did a autocad repair, but it didn't help
so I did a window 7 restore, when back two week, and its working.
thanks for the comments
