the properties palette started only showing the current properites for the drawing and not the properties of the entity selected. what causes this i am using autocad civil 3d 2013.
jason
Set PICKFIRST to 1.
checked that it is set to 1 i changed it to 0 and then back to 1 and it still the same not working. thanks anymore ideas of what it could be.
jason
Yeah, sorry, Pickfirst doesn't seem to affect this. Can you post your drawing?
Mark Green
Working on Civil 3D in Canada
yeah this is the drawing i am working with but it happens with any drawing.
jason
Mark Green
It's a longshot, but you don't happen to have PROPOBJLIMIT set to 0?
Repair install.
Have you tried Resetting AutoCAD Civil 3D 2013 settings ?
never recommend that to anyone else ever jay. that doesn't work and in fact it makes things worse not only does it not fix the problem now you have to re-configure your work enviroment also.
Sorry to hear that didn't help either, part of the instructions cover backing up any customized files prior to resetting.
Normally not the first thing I'd recommend but you'd already tried reinstall and repair which didn't seem to fix the issue either.
We've used the reset user settings a couple of times with success fixing various machine specific issues.
Have you also tried logging in as a new Windows User account to see if that makes any difference?
haven't tried that but i think if i do a uninstall and a total re-install that would fix my problem
jason
You don't have ProjectWise installed do you?
This happened to a couple of our users and the link took care of it.
