Was working on a drawing, then poof, they're gone. How do I turn them back on?
thanks.
Solved by Jay_B. Go to Solution.
Possibly the "minimize" button was toggled?
Click on it and it toggles through the various options.
Or _Ribbon command if not loaded.
Home Tab>Palletes>Click the hammer
I do this a lot. I like to use Ctrl+O to open a drawing and every once in a while, I'll accidentaly hit Ctrl+0 (that's a zero). Ctrl+0 will take you into full screen.
Try hitting Ctrl+0 and see what happens.
And that would be .RIBBONCLOSE
Brian makes a very good point as to what may have caused the issue to occur.
The Command CLEANSCREENON (Ctrl 0) forces RIBBONCLOSE.
If this is what occured you can use the CLEANSCREENOFF command to revert back to the way your screen looked previously (including reopening the Toolspace).
Glad to hear it's working again.
