Hi there,
I've been trying to create a new label style for my projected cogo points on a profile.
I want it to drag so i can place the text more proprely but it only drags into vertically. (See attachment for image)
I don't know what parameter can be change so it can unlock vertically ?
Any help ?
Solved by Neilw_05. Go to Solution.
I think that the parameter you are looking for is the dragged state display, under the dragged state tab in the label style composer window. Setting it for "as composed" gives me vertical text labels, while setting it for stacked text gives me horizontal labels.
If this doesnt work properly either (or I am misunderstanding you) try adjusting the setting in the label style composer under teh General tab for Orientation Reference and Plan Readability. On a side note, I get an error message when I try to view your picture, but I believe this is what you're looking for.
Hi there everyone,
Neilw, you were right ... i grabbed the wrong grip !
Simple as that !
Sometimes we then to look far for a solution when it's so simple.
Thank you again !
