when you select all objects but forgot to label the projection objects during the dialog box, afterwards is there a way to label all at once rather than one at a time with "ADDPROJECTIONLABEL"?
doing 3dpolyline projections. not i didn't pick the label there is just no way of doing all at once. label style in the projection dialogbox is not selectable.
Does select similar>> properties give any relief?
Your Name
Your Name
tried that before. the command says please select one object at a time.
Not sure why you cant get that to work. It works fine for me. either way you could change one and use match properties on the rest.
Your Name
Your Name
i am talking about when the label is not created on the projection objects. or deleted. how do you go by bringing them back without deleting all the projection objects and recreate?
Thats messed up. Looks like your option are
1. label one at a time
2. Erase and re-project
I would use option 2.
Your Name
Your Name
yeah. good enough lol. just be careful it's created next time.
Well glad we finally got on the same page.
Please select "accept solution" so other readers may be aware of your solution
Your Name
Your Name
