I've yet to find a solution to this and now it is really getting to be a problem.
When we apply surface projection gradings to feature lines, we get locked vertices on the featureline wherever the grading transitions from cut to fill. In turn these vertices create segments in the featureline which influence any labels applied to the line. I don't want a bazillion segment labels on my FL. I only want segment labels between the physical vertices and elevation points. Is there a workaround or is an enhancement request in order?
Your Name
Your Name
I can do that in land desktop too. Once you explode stuff you no longer can trust the model. Perhaps you've not heard the analogy that Land Desktop is like carving statues in stone and C3D is like molding it in clay.
Never said explode. move to site. yes that peace of grading would require monitoring, but I have yet to see a comprehensive model that would never require the users to keep an eye on certain aspects of it if that is not to your liking than you'll have to 1. live with multple lables 2. manually remove the repugnant ones, 3. have a statice peace that may require re-projecting in the event of a change.
Your Name
Your Name
Your Name
If you say so. we are typing at the same time 🙂
I think of it as re-ordering.
exploding circumvents the worflow with c3d and can result in unknowns. Moving to site uses c3d to reorganize the surface data, that IMHO is safer
Your Name
Your Name
