So I was using 2010 and had the Hec Ras Import Export Extension for civil 3d. I have since upgraded to 2012, it now seems that there is no Import Export extension for 2012 only the River Analysis Lab. Is this correct? If so, is there a video tutorial somewhere to teach me how to use this thing? O is there a way I can just get the import export extension for 2012 for Hec Ras without redoing the information. Please Help!
HEC RAS Import/Export is still in Civil 3D 2012, however, it's no longer an extension. You will find the commands here on the Ribbon (tab>panel>command):
Insert > Import (expanded) > Import HEC RAS
Output > Export > Export to HEC RAS
I hope that helps,
Charlie
Thanx,
I did manage to find it after some frustration and choice words. Thanx for the help and quick reply.
