OK... Spent the day in "Multiview Block" hell.... After a number of tries, out from the fire and brimstone my multiview block emerged in my profile view as if it were saved by an angel from heaven... Although still smoking, The "Top View" of the object appears in the profile view. My question is the "Top View" of multiview block objects the default view when projecting to objects to a profile view? What about section views?
Solved by JeffWright5789. Go to Solution.
Solved by AlmasSuljevic. Go to Solution.
Hi Jeff,
Is this what you are seeing? http://beingcivil.typepad.com/my_weblog/2010/12/projected-objects-show-as-flat-in-section-view.html
Yes... excellent... thank you...
Jeff,
Looks like you are finally enjoying Civil 3D.
Your frustration is turning into pleasure ? 🙂
Andrew,
http://projectobject.com/ The bomb for sure
Certainly success is sweet when it comes to C3D. It's like trying to approach a honey bee nest. You have to get stung a whole bunch of times but when you finally get the honey comb you forget how much it hurts getting there..
