Jon Rizzo wrote:
> Right - that's why this is a problem. If the user gives the profile the same
> name as the alignment (although they probably shouldn't anyways) it will not
> be checked in to vault and they will not be prevented from trying, or warned
> that it won't work.
> "Jason Hickey" wrote in message
> news:5258315@discussion.autodesk.com...
> Jon Rizzo wrote:
>> C3D 2007 SP1A
>> Create a drawing, drawing1.dwg
>> Create an alignment in the drawing "alignment1"
>> Add the drawing to the vault and share alignment1 to the project.
>> Check out drawing1.dwg
>> create a profile for alignment1 and give it the same name as the
>> alignment,
>> alignment1.
>> check the drawing back in to vault and share the new profile to the
>> project.
>> the profile is not added to the project, and no warning or error message
>> is
>> presented to the user.
>> I presume that this happens because the shortcuts are always named
>> "FileName:ObjectName" but the user should be made aware of this conflict
>> when it happens. This will be especially problematic when checking in
>> profiles that were created in land desktop if more than one alignment and
>> profile exists in the same drawing. All imported FG profiles are called
>> "FG" and Civil 3D allows this name conflict to exist, even though it is
> From what I've found, profiles can only live in the same drawing that
> the parent alignment lives in. For example, I can create an alignment
> and profile in drawing1, add the info to the project, and try to
> reference in the profile to drawing2 - won't work.
I agree. I think it's a Vault issue, myself.
Jason Hickey
Civil 3D 2007, SP1A
Dell Precision M70
2 GIG RAM, 256 MB nVidia Quadro FX Go1400
Intel Centrino 2 gHz Processor
http://beneaththelines.blogspot.com
