Active Contributor
JCyganiak
Message 1 of 5 (258 Views)
Project Back up
258 Views, 4 Replies
01-08-2013 06:01 AM
I'm trying to revise our file structure but running into a road block. Lets start by saying i have a (Autocad) folder, and within that folder i have other folders. I have a (CURRENT PLANS) folder which is always worked in, how can I copy it once it is submitted, paste into the (Autocad) folder, rename it Rev00, and have the Rev00 plan sheets not reference the base file in the CURRENT PLANS folder?
I am trying to keep backups of plan sheets but trying to avoid re-pathing the base file. I'm out of ideas.
Joe Cyganiak
Civil Engineering Senior Designer
AutoCAD Civil 3D 2014
HP Z620 Workstation 64-bit
Duel Intel Xeon E5-2620 @ 2.00 GHz
Ram: 48 GB
troma
Message 2 of 5 (242 Views)
Re: Project Back up
01-08-2013 07:09 AM in reply to: JCyganiak
I believe there is a setting for x-refs to have an 'absolute' path or a 'relative' path.  I've never looked too deeply into this, but I think if you have a relative path it remembers the path relative to the current drawing.  So the instruction is along the lines of 'Find the drawing called xyz.dwg that is in the same folder as this drawing'  rather than 'Find drawing xyz.dwg that is in this specified folder'.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
JCyganiak
Message 3 of 5 (230 Views)
Re: Project Back up
01-08-2013 08:08 AM in reply to: JCyganiak
The Devil is in the details! You're a genius! Thank You!
Joe Cyganiak
Ram: 48 GB
Valued Mentor
hardin
Message 4 of 5 (188 Views)
Re: Project Back up
01-09-2013 08:14 AM in reply to: JCyganiak
Another option is to use eTransmit. You can set the eTransmit settings to place all files in one folder or even bind xrefs. We use eTransmit to archive our projects. Sheet Set manager makes selecting the files even easier.
Valued Contributor
brian.strandberg
Message 5 of 5 (180 Views)
Re: Project Back up
01-09-2013 08:55 AM in reply to: JCyganiak
Another option would be to use the PROJECTNAME variable, assign a direct path to the new XREF folder.    This has the advantage that you can easily write a script to apply to many drawings.
