Civil 3D Forum
Program Failure with metric pipes
4 REPLIES 4
147 Views, 4 Replies
Can someone try this for me?
Start a drawing using the "metric by layer" template.
Change your pipe catalogs to Metric Pipe and Metric Structure
Create a pipe network by Layout. Under "Network parts list" choose "common
sanitary sewer" Click "OK"
using "pipes and structures", draw a simple 2 node, 1 pipe network.
click on the resulting pipe and bring up the pipe properties
Under the pipe properties tab, click on inner pipe diameter as if you're
going to change it.
It should hang (unless it's just my install), if you click on the rules or
information tab, then C3D should exit, without error statement.
I'm only a single seat here. This is fresh install with no modifications
made to anything.
C3D 2006, Win XP Pro SP2
FWIW, I havn't noticed this problem with imperial data.
4 REPLIES 4
yes - it is reproducible.
thanks for the detailed steps.
Daniel Philbrick
Autodesk, Inc.
"Ron Mills" wrote in message
news:4851563@discussion.autodesk.com...
going to change it.
made to anything.
"Daniel Philbrick" wrote in message
news:4851775@discussion.autodesk.com...
Whew!
Whew, as in, "It's not just me"? Ot whew, as in, "Man, another bug!"?
Sorry, Daniel. I love the product, but there is an issue or two. 🙂
Matt Kolberg
news:4851755@discussion.autodesk.com...
Whew!
"Matt Kolberg" wrote in message
news:4852008@discussion.autodesk.com...
I think the Whew covers both instances...
Rail Community
