I'm trying to create a profile of a pipe. I have elevation data for the pipe and natural ground I've created a surface from the natural ground then I created and alignment. Next I created a profile when the profile was completed I got broken lines and spikes for my pipe not a polyline that followed the natural ground. I'm at a loss as to how I could fix this and I'm very new to AutoCADD I'm a GIS person. Any help would be greatly appreciated. Thanks
There are several types of profiles none of which I am aware become broken lines or polylines for that matter. Profiles are objects. Is this a surface profile? you may want to create a Layout profile to establish you pipe profile. Or maybe consider using a pipe network and set the inverts/ slope of the pipe?
Joe Bouza
Could you post a screen capture showing the Alignment with the natural ground Surface Boundary displayed?
Thanks for the reply could you please explain in greater detial what a Layout profile is or what a pipe network and set the inverts/ slope of the pipe. I'm very new at this.
Yes you are new aren't you 🙂
I still would like to know what you did to get a profile of broken lines?
A layout profile is intended for design and is made up of tangent lines and curve types of your choosing Pipe networks are exactly that; they are objects that represnt pipes and structures. All these items are in the design panel of the ribbon. I could go on and on about these tools but you would get a quicker idea by going through the "Getting Started videos" on the startup screen. if the startup screen has been disabled you can access it from the help button on the ribbon. View the vids, do some tutorial, and ask questions.
Joe Bouza
Joe Bouza
@Anonymous wrote:
This is what I did. I added point data that had elevation data. Then created a surface. By going to Surface/Create Surface and following promps. Next I create and Aligment follow the promps. Next I created the surface from the natural ground and the pipe. I could have missed some steps. Thanks for the help.
Forgive me for breaking this down
you added point data: by creating points/ point group?
you created a surface: from the point data?
you created an alignment: from the alignment palette?
you created the surface from natural ground and the pipe: you mean a surface profile and what pipe - the alignment?
Joe Bouza
Sorry for leaving some information out. I Ialso needed to add an alignment but I thought an alinment was part of craating a profile. I created a surface from natural ground points. Then I imported a (which is supposed to be a pipe) point file with elevation data attached and then I used that to create the profile. (I'm guessing thier is something that I'm not doing right with the pipe points). I'm open to another way of creating this. So the end result needs to be an alighment, and a profile of a pipe.
Joe Bouza
