Civil 3D Forum
Profiles
2 REPLIES 2
jabei
310 Views, 2 Replies
Profiles
Is there a way I can take my finished ground profile in my profile view and get Civil 3d 2011 to label the pvi's in the plan view?
2 REPLIES 2
Civil3DReminders
in reply to: jabei
Yes, check out the labels for the alignment. There is a label type to do what you are looking for.
Christopher
http://blog.civil3dreminders.com/
onsionsi1
in reply to: jabei
Yes, absolutely you can do that.
1- Go to alignment labels.
2- Go to Profile geometry points and select point label style to code and stations and press the down arrow to select an action and press the bottom content as shown below
3-Select the properties (PVI Elevation) and then press the Right arrow bottom to add this content to your label style and eventually you can erase other content or leve it as you want to display.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
Rail Community
