AutoCAD Civil 3D General Discussion
*Expert Elite*
Jeff_M
Message 11 of 25 (1,033 Views)
Re: Profiles Not Synchronizing upon Open
04-15-2013 05:43 AM in reply to: tspoon005
Still manually sync'ing here. And sending reminder emails to support.
Jeff_M, also a frequent Swamper
MKearney028
Message 12 of 25 (1,001 Views)
05-02-2013 07:07 AM in reply to: Jeff_M
So, this is still an issue, right? I think the easiest temporary fix would be to add the line
(command "synchronizereferences")
into the acaddoc.lsp file. I'm slightly hesitant because I'm sure it's going to slow down the opening of files, but does anyone else see any other problems with this? If not, I think it should work until Autodesk updates the software to resolve the issue.
*Expert Elite*
Jeff_M
Message 13 of 25 (995 Views)
05-02-2013 08:11 AM in reply to: MKearney028
I tried that, for about 3 drawings worth of opening. Was more annoying than them not synch'ing. I was informed of a workaround that did work for most of my projects with minimal changes to my workflow. See this thread: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Anyone-have-some-drafting-supplies/m-p/3875859#M20191... hopefully that will help you.
MKearney028
Message 14 of 25 (986 Views)
05-02-2013 08:57 AM in reply to: Jeff_M
Thanks Jeff, but I think the issues on that thread are a little more in depth than what I am running into. My concern is mainly with Surfaces, Alignments and Profiles, and with that, mostly the naming of these items.
If I have an empty file and create an alignment, DRef that into a new dwg, and change the name of the original alignment, it will not update when I reopen the second file. (with all the necessary closes and saves)
We don't have large pipe networks, so the load isn't much longer, so I think I'm going to stick with the code in acaddoc.lsp for now.
Thanks though.
Active Contributor
tspoon005
Message 15 of 25 (943 Views)
05-28-2013 08:10 AM in reply to: MKearney028
After looking at the thread posted by Jeff M, I have better diagnosed the problem, but unfortunately this just creates a new problem.
Diagnosis: I have three drawings in question, a water profile design drawing, a sswr profile design drawing, and a utility profiles "sheet" drawing.  The design drawings are xref'ed into the sheet drawing where they are displayed on our title block.  My problem was that the water profiles would not show up until I manually synched the drawing.
Now, I learned that the manual sync not occurring is due to a bad xref.  Through trial and error, I determined that the sanitary sewer design drawing was the bad xref.  Whenever this xref is unloaded or detached from the destination drawing, the water profiles show up without me having to manually sync.
FYI this matters to me because I usually publish the whole sheet set at once.  The publish command opens the drawing and plots it (all in the background).  Thus, if manual sync-ing is required, then I get a sheet set without waterline profiles.
Solution/New Problem: Since the solution is to simply unload the SSWR xref, then I do that.  Now, I have to open the drawing (which automatically sync's my waterline profiles!) and then manually reload my SSWR design xref to get all the pieces in place to plot.
So, this might help some of you, but for me the real question is now, HOW DO I STOP THE "BAD" XREF FROM ALLOWING AUTOMATIC SYNC_ING?
So far I have tried auditing the source drawing, and detaching and reattaching, but to no avail.  Thoughts?
Active Member
lauraford5837
Message 16 of 25 (906 Views)
06-19-2013 08:18 AM in reply to: cfarrow
 I CURRENTLY HAVE TWO PROJECTS WITH THE SAME PROBLEM OF NOT SYNCING UPON OPENING, AND FOR MOST OF MY PROJECTS THIS IS NOT AN ISSUE,
SO  I AM MANUALLY SYNCING AS WELL, ANY SOLUTION YET???
WILL IT HELP FOR THOSE OF US WHO HAVE NOT OPENED A TICKET TO ADD ON TO POOR SETH HALL'S WORK LOAD. WILL THIS MAKE AUTODESK LOOK AT THIS AS A "REAL ISSUE"?
THANKS,
LAURA FORD
*Expert Elite*
Jay_B
Message 17 of 25 (903 Views)
06-19-2013 08:38 AM in reply to: lauraford5837
Laura, Does this problem only occur in plan and profile sheets with Pipe Networks dref'd into dwg and the source Pipe Network dwg is also attached as xref and loaded in the plan and  pfl sheet? If so This previous thread may help.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Active Member
lauraford5837
Message 18 of 25 (900 Views)
06-19-2013 10:39 AM in reply to: cfarrow
Jay,
  Thanks so much for the solution. I have seen This post before I had thought I did not fall into that criteria (I only had the surfaces drefed. However when I removed the xref of my surfaces the drawing worked out just fine.
  Now the dilemma is we (we being a very large group) will typically have files that will have to see both, for example xrtopo, will typ have existing surface features (roadways, sidewalks, pond nwl, etc) all in 2d. and existing surface in 3d. in p&p I need the existing surface shortcuted in for the profiles and the linework from the surveyor in plan. there must be an easer way. This was not an issue in earlier versions...was it? I can not be the last one to still draw anything in standard 2d linework.
Thank you again!!!
 Laura Ford
*Expert Elite*
Jay_B
Message 19 of 25 (897 Views)
06-19-2013 10:46 AM in reply to: lauraford5837
What version and SP are you currently using?
I hadn't heard of any issues with surfaces and this behavior, it seemed to be limited to Pipe Networks around here.
I've had many dwg's where there was an xref containing EG surface source xref and EG surf was also dref'd into a plan sheet
and don't recall any issues.
So in your situation it sounds like you don't have Pipe Networks in the mix at all via xref or dref?
Jay
C3D 2014 SP2
Active Member
lauraford5837
Message 20 of 25 (890 Views)
06-19-2013 11:09 AM in reply to: cfarrow
I do have pipe networks in the jobs in question. They just do not affect the sheet that has become today's problem child, the profiles being shown are made up of an alignment (made in the sheet file, And strictly for that sheet And that sheet only). And an existing grade (which was both dref, And xref) the sheet was made just for a county comment wanting to see a profile view of an existing pressure pipe  (drawn in 2d) and how we had planned to modify the pipe (also linework in 2d) so the only item (in this situation) that is both xref/dref is the existing surface...And when I remove the xref, I have no problem proceeding as normal, drefs work fine. The other project in question is more full blown and has xrefs and drefs all over the place. Another machine in my area, that is not having this issue and can open my dwgs just fine is using c3d 2012 sp2..I am using c3d 2012 sp2.1. Can anyone else confiirm the sp2 to sp2.1? This may help pinpoint the probelm.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
