Civil 3D Forum
Profiles / Alignments
12 REPLIES 12
Message 1 of 13
361 Views, 12 Replies
I have an alignment and profile created for a mteric project I am working on.  The alignment is set up so it starts at 10+00 but when the profile is created the profile horiz axis starts at 100+00.  Anyone have a clue what might cause this?
12 REPLIES 12
Message 2 of 13
owenmull
Is this in the profile view? If so, check the Profile View style settings, and see if it is in there.
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
Message 3 of 13
in reply to: owenmull
yes in profile, everything is set to 10+00 but its labelling it as 100+00
Message 4 of 13
sjg
Do you have multiple alignments within your project, maybe one that starts at station 100+00. In the wizard to create the profile view, maybe you didn't select the correct alignment.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Message 5 of 13
in reply to: sjg
yea, its the correct aligbment
Message 6 of 13
mathewkol
It could be the band style or the profile view axis style.  Somewhere in there you have a text component set to have 100 before the 00.  It will be one of the two places I suggested.  We could tell you for sure if the DWG was attached.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 7 of 13
in reply to: mathewkol
well if anyone could take a look at the drawing and see if you see what the problem would be I would appreciate it.  I cant figure it out.  Thanks!
Message 8 of 13
i FIGURED THIS OUT.  iT WAS IN THE BAND STYLE, WHICH MAKES SENSE.
Message 9 of 13
sjg
Appears to be due to station character position within your major station band label. See attached image.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
Message 10 of 13
in reply to: sjg
Thanks for taking a look
Message 11 of 13
wfberry
Your original post was:
"The alignment is set up so it starts at 10+00 but when the profile is created the profile horiz axis starts at 100+00.  Anyone have a clue what might cause this?
This was not the case, the original Aligmnent station was 10+000 which for all practical purposes is 100+00 (displayed incorrectly).
Bill
Message 12 of 13
in reply to: wfberry
THERE IS A HUGE DIFFERENCE BETWEEN 10+00 AND 100+00
Message 13 of 13
wfberry
Look at this closely 10+000 and 100+00 are the same.
Bill
Rail Community
