When inserting a piece of my watermain into my profile view, the watermain is not stopping at the edge of the first profile view. Instead it just continues out of the view. See attachment. When I change the style of the pipe to just centre line I do not have this issue. It seems the hatching is the issue. I have done this exact same before without this problem and I cannot figure out how to fix it. Thanks in advance!
Danny
The sanitary system appears correct. This was probably done by draw pipes in profile command.
I suspect the water main is a projection of a feature line? If so, can you break the feature line at the station that you want the profile to stop at. Cheezy work arond but it might work if this is how you are putting the watermain into the profile.
