Hello! I have a little issue with profile view. I want to put label on specified place, for example if i have bridge pillar somewhere on my alignment and profile i want to have point there. I want to put Station in specified by me place is this possiable and how ? Here is drowing of something like that:
Solved by odoshi. Go to Solution.
You can put a grid line at Sample Line Stations. So create a sample line at the bridge piers and freeze them if you want. Then turn on the display of the component in the Profile View Style.
This will add a vertical grid line on your profile view horizontal axis. There is also a section data band set you can customize to include profile1/2 elevation.
Mike
This worked ! Thank you ! A friend of mine told me another way to do it, more simple way, just add Station equation in my alignment, then turn bands for equations on and it works the same way.
