Civil 3D Forum
Profile view data level difference units
7 REPLIES 7
Message 1 of 8
trevj
742 Views, 7 Replies
In my profile view I have existing and proposed levels in m.
The level difference is also in m but I'd like it to be scaled to show mm, as this is quicker to read on site.
Does anyone know of a way to achieve this, please? Is there some way to edit the equation and multiply by 1000?
Thanks.
7 REPLIES 7
Message 2 of 8
tcorey
in reply to: trevj
It is a wish list item to allow Expressions to be used in Profile Bands.
The workaround I use is to create an expression in Profile Major Station labels, create a label style that uses the expression. To get it to show up where you want in a band, set the Anchor Point of the component to Anchor Station Extension. This way all the labels will be aligned and then you can use a Y offset to move them down so they line up with your band. Edit your Profile Labels, add this label style and set the correct increment.
Best regards,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 8
mathewkol
in reply to: trevj
There should be no need for any expression. In the label style composer can you not just select mm as the unit? For every other label style you can. I'd attach a screen shot but for some reason C3D can't be installed on my BlackBerry.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 4 of 8
tcorey
in reply to: mathewkol
Ha. Dumb American, me, didn't realize you can just change your units to mm. Maybe I shouldn't answer when someone's quesiton is in a foreign language, metric.
Thanks, Matt!
Tim Corey
Redding, CA
Message 5 of 8
mathewkol
in reply to: tcorey
Any time.
Matt Kolberg
Message 6 of 8
trevj
Thanks. I navigated my way there and it works.
Millimetre isn't listed, but manually editing 'Ucm' to 'Umm' works. Combined with 'sign always' this is just the trick!
Message 7 of 8
trevj
in reply to: tcorey
Pas de problème!
Message 8 of 8
Rohit.Kaushik49XCJ
in reply to: trevj
Hi, Can you please elaborate how you got to the lable style set editor to change the units in mm. A screenshot might help. Thanks.
Rail Community
