Hi All,
I need some help here. I am a bit new to the program, and I am already glad with what it's capable of. Right now I have created a profile of my alignment, however the vertical geometry of the existing and finished ground comes in two values, one value to 2 decimals and the pther to 3 decimals. I would like to see only one value, how do I change this?
Also, the vertical geometry bands of the existing and finished ground come with stations attached to them. I would like to remove these and have an independent band of stations.
The third problem, the vertical and horizontal geometry data seems a bit undrefined, how do I refine it to look much smarter like I've seen with other people's work.
Lastly, the superelevation band comes out blank, where could the problem be?
I've attached a snaphot of what am trying to explain.
I appreciate you help!
Hillary
Solved by troma. Go to Solution.
Hi Hillary,
Follow this procedure:
1) Go to profile view properties
2) Select Bands
3) Select "Pick Band Style" Under Styles column
4) Edit the Current selection
5) Edit theTitle Text --> Compose label (do the adjustments by veiwing the preview side by)
6) Edit the Labels & Ticks--> Compose label (do the adjustments by veiwing the preview side by)
7) Apply ---> Ok.
This way you can solve your first three problems.
About your last question, you need to calculate the superelevation for the alignment using the "Edit / Caculate superelevation tab, then only it will be displayed in the profile band.
Please appreciate the answer by giving the kudos or accepting it as the solution, if it helped you.
About the data being "unrefined".
I suspect you are profiling a surface. Your vertical data will be much more 'refined' if you draw a profile 'By Layout'. This way you can control the exact PVIs, % grades etc.
Mark Green
Working on Civil 3D in Canada
Thanks for the response. I've tried your suggestions and they work well. However, the bands for the vertical and horizontal geometry still look disorganised. Please see attachment(NOTE: the 1st attachment is my work, the second attachment is how I would like the data in the tab look like).
Thanks again, in advance
Yeaaah Troma,
I've got your point! It has worked!
Now what am left with is the super elevation,how do I get this thing to calculate the super elevation?
Thanks guys I appreciate.
I have never used the 'geometry' data bands. However, looking at yours I make these observations:
one
Click on the profile, right-click and go to the profile properties. Remove the link to the surface by setting the profile update mode to 'Static' rather than 'Dynamic'. Then edit the profile and remove some PIs.
two
On the Home Tab of the Ribbon, Click Profile > Profile Creation Tools. Create a Profile by layout, snapping to your existing surface profile where appropriate. Then set your band to use this profile as the data rather than the surface profile.
Mark Green
Hello All,
Everything seems to be working out just fine, thanks to you guys. Still have one more issue, I inserted two bands, one for the finished and existing ground level. However, when I change the title in the title box,the other box title changes too. This gives me bands with the same title, something undesirable. How can I handle this? (see attachment)
Thanks again!
Click on the profile view (grid or band).
Right-click > Profile View Properties > Bands
Change the referenced profile in the profile drop-down for the band.
Mark Green
Hi troma
You explained how ot make the data "unrefined" but is there a way to make the profile itself less accurate. I found how to modify the distance between the ticks, but all it does is hide some of them, the graph at the top (the surface) remains unchanged.
Mark Green
Check out the screenshot i attached. It would be nice if i could make the whole profile look more like the brown line, however what's more important is that the first section, between the those two signs, needs to be completely flat. Do you know how i can remove those lines i've circled. I found how to modify the space between them but i need them completly gone.
Right click your profile view and select edit profile view style. In the display tab, switch off the major, minor grids(See image below)
Mark Green
