Hi!
Does anyone know how to change the Profile view band labels?
We needed to change the Station names for the alignment and for the profile view from 00+100 to 1000+100 etc.
Changing the alignment starting station name (Alignment properties) makes the profile move (as it stays linked to 00+100 station), creating the new labels style for the Alignment helps to keep the profile, but with labels 00+100 etc.
I have created new Profile view label style using the same expression as for the alignment, but when I am trying to create new Profile Data Band Style the Label style I created is not listed inh the Label Style composer.
Will be gratefull for any help.
(p.s. the profile was created from a polyline using Quick profile picked from drawing and Exported to LandXML )
One way I change the alignment labels it to add an equation station. for example, instead of the alignment starting at 0+00, lets say it starts at 450+00 or 1000+100 like you said.
1 First select the alignment
2 right click and select alignment properties
3 Under the Station Control Tab
4 Add Station Equation-specify the starting point
5 In the station ahead column specify the station you want it to start with. Mine says 449+23.85'. and hit apply
FYI-I am using Civil 3D 2012. Not sure what version you are using.
