Hi, I've been having a problem to make the bands at the start/end staions in profile view appear.
I've tried close to everything on the forum by now: checking/unchecking the checkbox for start/end stations, messing with the geometry points, turning on/off several components on the band display tab, recreating the profile from scratch, checked the profile data band labels for major/minor stations and horizontal/vertical geometry points, tried changing the weeding, altering the profile range to start/end 0.001 before/later. The latter managed to show the label, but the value for station was wrong and there was none for elevation.
Is there a solution for this?
I'm not sure I follow what you're trying to do. The Begin and End Surface Profile Staion and Elevations can be turned on by adjusting the Weeding down to zero.
If you're trying to display the Structure Stations & Elevations, then use a Pipe Network Databand to display that information.
Jay_B,
Unfortunately that doesn't work either, when adjusting the weeding to 0 the ammount of information displayed is way too much, I've tried changing the weeding to 0 and choosing fewer geometry points to label, but still there's too manylabels overlapping.
This particular profile has a pipe network, but this problem is for any profile.
