Show only
Search instead for
The labels normal anchor point is the bottom outside diameter of the pipe, but when dragged the anchor snaps back to the cl of the pipe.
The only workaround I was able to come up with is a "static" leader made up of two lines and an arrowhead block, which you can only slide up or down the pipe with the desired appearance but can't stretch.
The attached image shows the Civil 3D pipe label above and the desirable text/leader legacy version below.
