AutoCAD Civil 3D General Discussion
*Expert Elite*
AllenJessup
Message 1 of 4 (192 Views)
Accepted Solution
Profile Middle Ordinate Expression
192 Views, 3 Replies
04-09-2012 06:10 AM
I'm trying to build an expression to display the Middle Ordinate for profile curves. I don't usually do this but it's required for this project.
The first thought was to subtract the PVI elevation from the profile elevation. The PVI elevation is easy but I don't see an easy way to get the profile elevation. I can go through the whole formula for calculating the grade. But that will probably take some debugging.
Does anyone know a better way.
Allen
Use the "Tangent Offset at PVI" label property. This is the distance from PVI to the profile elevation. Here is the expression I use to get the midpoint elevation.
IF({Grade In}<{Grade Out}, ({PVI Elevation}+{Tangent Offset at PVI}), ({PVI Elevation}-{Tangent Offset at PVI}))
*Expert Elite*
Jeff_M
Message 2 of 4 (190 Views)
Re: Profile Middle Ordinate Expression
04-09-2012 06:23 AM in reply to: AllenJessup
Jeff_M, also a frequent Swamper
*Expert Elite*
AllenJessup
Message 3 of 4 (186 Views)
04-09-2012 06:36 AM in reply to: Jeff_M
Very nice Jeff. Thank you. I'll see if I'm talented enough to use it in a few minutes.
Allen
*Expert Elite*
AllenJessup
Message 4 of 4 (181 Views)
04-09-2012 06:53 AM in reply to: Jeff_M
Worked very well. Thank you.
I'm going a little batty trying to match the labels on the attached.
Allen
Post to the Community
New Post
Need installation help?
