Civil 3D Forum
Profile Middle Ordinate Expression
9 REPLIES 9
Message 1 of 10
AllenJessup
899 Views, 9 Replies
I'm trying to build an expression to display the Middle Ordinate for profile curves. I don't usually do this but it's required for this project.
The first thought was to subtract the PVI elevation from the profile elevation. The PVI elevation is easy but I don't see an easy way to get the profile elevation. I can go through the whole formula for calculating the grade. But that will probably take some debugging.
Does anyone know a better way.
Allen
Allen Jessup
CAD Manager - Designer
9 REPLIES 9
Message 2 of 10
Jeff_M
in reply to: AllenJessup
Use the "Tangent Offset at PVI" label property. This is the distance from PVI to the profile elevation. Here is the expression I use to get the midpoint elevation.
IF({Grade In}<{Grade Out}, ({PVI Elevation}+{Tangent Offset at PVI}), ({PVI Elevation}-{Tangent Offset at PVI}))
Message 3 of 10
AllenJessup
in reply to: Jeff_M
Very nice Jeff. Thank you. I'll see if I'm talented enough to use it in a few minutes.
Allen
Allen Jessup
Message 4 of 10
AllenJessup
in reply to: Jeff_M
Worked very well. Thank you.
I'm going a little batty trying to match the labels on the attached.
Allen
Allen Jessup
Message 5 of 10
I am using Civil 3D 2014.
When I try to use this expression, it tells me "undefined property".
Please help.
Message 6 of 10
Jeff_M
in reply to: Kenth_Kristoffer
Kenth, this expression works fine for me in C3D2014 (and all other versions I have installed). Which label style are you trying to apply it to?
Message 7 of 10
Kenth_Kristoffer
in reply to: Jeff_M
I tried to apply it under:
Profile>Label Styles>Station>Major Station>Expressions
and
Profile View>Label Styles>Station Elevation>Expressions
Message 8 of 10
Jeff_M
This is only applicable for vertical curves. Therefor, you will only find the needed items in the Profile Label Styles->Curve expression builder.
Message 9 of 10
Kenth_Kristoffer
in reply to: Jeff_M
Thank you, I found it.
Message 10 of 10
mlokay
in reply to: Jeff_M
This is great thanks.   I would like M value to be a distance not an elevation however.   Any help on how to achieve that?
Rail Community
