Civil 3D Forum
Profile Line Styles
11 REPLIES 11
Message 1 of 12
1026 Views, 11 Replies
Profile Line Styles
I am creating profiles and I can not get the existing grade linetype to show up as a uniformed dashed line.  The layer is set up for a dashed line but   the existing profile line is made up of too many nodes to make the linestyle look right.  Anyone know how to solve this?
11 REPLIES 11
Message 2 of 12
tcorey
Hello MartinLotofEights,
Make the profile Dynamic and the plinegen functionality will become active. Also, check your linetype setting in the profile style and pay attention to the linetype scale here as well.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 12
in reply to: tcorey
thanks....it wont let you change an existing profile from static to dynamic will it?
Message 4 of 12
Per the attached you can see the profile is created with numerous nodes which causes the linetype to not be presented correctly.  The program will not let you change it from static to dynamic.  I know microstation has a command to change this.
Message 5 of 12
Message 6 of 12
Joe-Bouza
plinegen should take care of that regardless of the vertices.
if the profile was a surface profile and switched to static you should be able to set back, but if it never came fro a surface it wont
Joe Bouza
Message 7 of 12
in reply to: Joe-Bouza
plinegen set at 1 or 0 seems to have no effect at all on the profile. it is a profile created from a surface and it will not let me change it between static and dynamic
Message 8 of 12
Jeff_M
Which version of C3D are you using?
Jeff_M, also a frequent Swamper
Message 9 of 12
in reply to: Jeff_M
I am using 2013.
So I am creating this profile from an existing groudn surface and when I create it it doesnt give me the option to change it from dyanamic to static (it is greyed out).  The existing ground profile is creating with many nodes which looks like it causing this issue.
Message 10 of 12
when I create the profile the attached is what I get.  It will not let me change between dynamic and static.  I dont know if that is the cause of this or not.
Its odd becaue I can create other profiles in the drawing file and it will let me change between the two.
Message 11 of 12
Jeff_M
Martin, your image shows an icon for the profile type to have been created from a file, not a surface. In this image I show a clip from yours and a clip from one of my profile views showing the diferent types, first one is a layout profile, second one is a surface profile, and the last one is a profile from file. The profile from file is always static so you will not get the linetypegen to work with that profile unless you explode it to a polyline.
Message 12 of 12
Jay_B
Try Joe's method in this post for convert Surface Profile to Layout Profile.
I used it to convert a Profile from File to a Layout Profile and it worked.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Create-proposed-profile-from-surface-profile/...
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Rail Community
